Rubber bushing kit available?
I'm looking to replace my rusted through rear X-member. While I have the rear diff dropped I am considering replacing every rubber bushing and mount in the rear or the car. I have seen kits for older cars (the cars that are typically being restored). Is there such a kit for the legacy? If not, can anyone list all of the bushings,links, and mounts that are back there on the AWD? I don't want to forget anything when I start ordering. Thanks!
- Findlay
"You say grease monkey like its a bad thing"
http://www.toolsource.com
Lateral link bushings x8 (6 the same and 2 different)
Front and rear trailing arm bushings x4 (2 front and 2 rear)
subframe mount bushings x 4
rear diff mount bushings x 4 (2 upper and 2 lower)
diff outrigger bushings x 2
swaybar mount bushings x 2
swaybar eyelet bushings x 2 (only if you have a '91)
That's about all I can think of off the top of my head.....
Rio Red '91 Legacy SS
If you want upgraded aftermarket bushings, many bushings for the newer Imprezas fit.
'00 Impr RS - sold
Pretty much any bushing for the 93-01 Imprezas fit our cars.
I know the rear diff mounting bushings are different than some RSes (I know the '99, but probably others). I was lying under my uncle's RS and noticed that the rear diff bolts to bushings directly in the crossmember instead of a rear support which in turn bolts to the subframe.Legacy777 wrote:Pretty much any bushing for the 93-01 Imprezas fit our cars.
All the suspension bushing should interchange perfectly, though. I have a full set of Impreza polyurethane suspension bushings waiting to be installed.
I got my set from SuperPro, an Australian company. The US distributor is globalperformanceparts.com
Yeah....the rear diff bushing is about the only one that won't fit....sorry about that.
