I was changing my fuel filter this afternoon and noticed that I had a loose tube. I traced it back to what I think is the Duty Solenoid Valve (16102AA012). It comes off the bottom of it. Looking around, I couldn't see anything obvious where it attaches.
Anyone have some pointers?
Missing tube off Duty Solenoid Valve?
'11 WRX Limited
'94 TW | R.I.P.
I think it might be a relief hose, and should probalby connect to the bit that goes between the airbox and the turbo inlet.
Legacy Central
IronMonkeyL255
I agree with him.DLC wrote:I think it might be a relief hose, and should probalby connect to the bit that goes between the airbox and the turbo inlet.
My car didn't seem to want to boost quite right when I had it capped off.
Rio Red '91 Legacy SS
There's a nipple on the resonator box after the MAF sensor, before the turbo. That's where it gets connected to.
IronMonkeyL255
Though it may have broken off.Legacy777 wrote:There's a nipple on the resonator box after the MAF sensor, before the turbo. That's where it gets connected to.
I know I broke mine off one day while putting the intake back together. Ended up doing the coffee mug mod instead of replacing it.
