well i ended up recieving a very nice resonator delete pipe for an ej20g which means it doesn't have a fitting for the hose going to the charcoal canister...
i want to install this tomorrow.should i just leave that line open to the air, or will it cause any driveability issues?
what should i do with this hose?
1994 SS "JDM-OEM"
1994 gt wagon, next build
1994 turbo wagon
1994 turbo wagon
You need a check valve in the line so you don't get boost building in the canister or it blowing fumes out if the cps fails or opens.
It should be post MAF sensor, otherwise you'd be measuring air twice, and a/f ratios will be off.
