what should i do with this hose?
subaru_styles
Post by subaru_styles »
well i ended up recieving a very nice resonator delete pipe for an ej20g which means it doesn't have a fitting for the hose going to the charcoal canister...
i want to install this tomorrow.should i just leave that line open to the air, or will it cause any driveability issues?
1994 SS "JDM-OEM"
1994 gt wagon, next build
1994 turbo wagon
dzx
Post by dzx »
could you use a n/a charcoal cannister?
///M
'93 Legacy SS - part out
You need a check valve in the line so you don't get boost building in the canister or it blowing fumes out if the cps fails or opens.
subaru_styles
so if i decided to plumb that hose back in, does it matter where it goes?
thinking i might tap a barb into the air box and hook it up there. is that ok?
1994 SS "JDM-OEM"
1994 turbo wagon
It should be post MAF sensor, otherwise you'd be measuring air twice, and a/f ratios will be off.
