Has anyone cut out chunks from the rear doors, trunk or hood, and reinforced them with fiberglass or tubing?
I took them off today and holy christ are they heavy, 50 lbs a piece easy
Weight reduction... again
madmallard
dscoobydoo
dscoobydoo
Don't bother with the JDM beams.
I had one and tinfoil is stronger.
You would be better to get another beam from a JY and cut it yourself.
The N/A and SS beams are the same.
You pretty much did all the major stuff; not much left to pull.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
BAC5.2
Yea, you got most of it. Only thing I can think of is remove your airbag system (if your 92 is so optioned, i don't remember it being so).
Other than that, cutting chunks out of the hood and rear doors and trunk is fine. Your caging it right? I'd find a junkyard car and cut the C pillars out of them. Just take the inner layer, chamfer it, weld it over your stock panel, then remove the speaker deck. You'd probably only lose a pound at best, but if every pound counts.
I recently traded my fixed mirror for someone's auto-dimming mirror so they could save weight. Net savings of 8.7oz for them, and it was worth it.
