WTB: offset clutch fluid resevoir tank
Bheinen74
Post by Bheinen74 »
does anyone have a offest clutch fluid resvoir tank for sale for me?
or what fits from newer cars?
i want to get to my tmic install soon.
[http://www.oksubaru.com/gallery/main.php?g2_itemId=2099I stole this picture to show how you NEED the offset one, and it is still a tight fit in this pic.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Bheinen74
Post by Bheinen74 »
where can i get one? part number or anything please.
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
kleinkid
Post by kleinkid »
What IC are you going to use? I am usiing a FXT IC and have the offset clutch master cylinder reservoir, and it is under the IC. With the earlier USDM WRX IC, the offset reservoir might not be under that IC though. You can do a search and find a remote reservoir set up. The reservoir is connected by a tube to a cap on the OE reservoir. There was an SS at Subiefest 1 that had that set up and it looked like one way to go.
Bheinen74
Post by Bheinen74 »
i am using a 06WRX tmic, so it is the same as the FXT one. I really want the offset one.
i dont want to just cut mine down, because i want my maintenance checks to not have to involve removing the tmic
--wait, you say yours is still under the ic even with the offset.?
i want to get this done, so i can figure out the Y pipe to turbo connection. I am using the VF11 factory turbo.
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
n2x4
Post by n2x4 »
I was searching for the offset res. too. They're hard to find anymore, Frank doesn't even have them. I've got the 06 TMIC and even though the IC rests on the MC cap, I can still close my hood. I don't know if it's really all worth the hassle to relocate stuff. I've got to take the IC back out and check my tranny fluid, so I'll see if I've done any damage at that point.
SUBARUEHS Racing
IronMonkeyL255
Post by IronMonkeyL255 »
I just cut down my stock reservior. I have about 1 or 2 mm of clearance, so it's all good.
Rio Red '91 Legacy SS
Bheinen74
Post by Bheinen74 »
bump again...bueller, I mean Blackbart.....do you have leads on these anymore?
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
