wobbly shifter :(
wildacex187
wobbly shifter :(
hi i just recently purchased a legacy ss. its a fun car but the shifter is all wobbly. wat can be the culprit here? i was told something about tranny bushings but wat came to mind was the tranny mount.
New shift bushings like these:
http://turninconcepts10.chainreactionwe ... 02840dc2bc
and a new return spring like this:
http://bbs.legacycentral.org/viewtopic.php?t=20945
would probably help out a lot.
SUBARUEHS Racing
Threshld1
Note those Kartboy bushings are for the stay bar and while they will help a ton they will not eliminate all the slop. I found the bushings on my knuckle between the gearbox selector fork and the linkage were missing entirely. These can be gotten from the dealer, prolly going to have to be special ordered but they make a HUGE difference. Or just do what i did and find yourself a WRX linkage and get the kartboys and call it a day. Here are some pics if it helps:
http://s31.photobucket.com/albums/c389/ ... 20Linkage/
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
91 SS AT
wildacex187
the knuckle meaning the one with the rubber dust shield? do u know the part number by any chance?
wildacex187
is this the one u talking about threshld1? http://turninconcepts10.chainreactionwe ... 02840dc2bc
5sp 94 ss
wtb: power antenna, a rear right abs sensor and a rear lsd bolt on diff . pls pm me if u have these parts
Threshld1
That is the one between the lever and the linkage inside the cabin. Then the other two sets of two are on the knuckle which looks like this:wildacex187 wrote:is this the one u talking about threshld1? http://turninconcepts10.chainreactionwe ... 02840dc2bc
I do not know the part# off hand, ill dig through my pictures when i get home and see if i can find them.
As for the square one it goes on the back side of the stay bar (the rod the ball of the shift lever seats in) and has the circular bushing in the front. It bolts to the back side of the chassis. Seen here:
http://s31.photobucket.com/albums/c389/ ... CN0647.jpg
FYI these kartboy bushings are universal for 5mt staybars. IE it will work with the old legacy or a wrx assembly.
91 SS AT
91 SS AT
Threshld1
Oh i should also add that knuckle i linked you to is the newer version. As you can see in this picture:
http://s31.photobucket.com/albums/c389/ ... CN0643.jpg
The old legacy style has a female end with the bushings in the lever bar where the WRX one has them in the knuckle.
91 SS AT
91 SS AT
wildacex187
Threshld1
well im suggesting get new bushings for the old style legacy knuckle from subaru. The updated style knuckle from that site will not work with the old legacy shift assembly, you have to get the entire assembly from a newer rs or wrx
91 SS AT
91 SS AT
wildacex187
Threshld1
Well you need 4 bushings for the knuckle, i think they are all the same but im not sure, ill get you part numbers when i get home.
The walbro is just the normal 255lph pump i got local with a subaru install kit. Everything should drop right in
91 SS AT
91 SS AT
douglas vincent
Wobbly shifter also means....... shifter is about to fall off!!!!!!
Yep, happened to TWO of my cars. Now I have factory short shifter.
wildacex187
douglas vincent
It doesnt break, it simply falls off the metal post that it is attached to. This post is very short, but still wholly funtional.
- quasi-mod-o
The one-piece knuckle that you guys are talking about is part # 35047AC030. The newer Subarus use this from the factory, so that in the event they need shifter bushings later, it's a couple fewer steps.
This knuckle, as others have said, is necessary to bolt stock WRX or newer short-throw shifter designs to the shift rod on the transmission. Legacy777 used it to install his STi short-throw shifter in his Legacy when he did his AWD/5MT swap.
wildacex187
my legacy is 1994 and its white with a rust pearl lol.
subyluvr that part number will directly bolt on to stock shifter?
can i use this shifter on my car?
http://cgi.ebay.com/ebaymotors/93-94-95 ... 3571QQrdZ1
how about this pulley?
http://cgi.ebay.com/ebaymotors/93-01-94 ... 2922QQrdZ1
i know these are cheap ebay parts but i dont want to pour too much money into this car. i have another money pit for that
quick question. sometimes when i brake the pedal goes down about an inch from where i move to and the brake pressure doesnt change. the last owner told me its hill assist something. can it be disabled without disabling the abs? hows the abs on these cars anyway?
wildacex187
i've been reading up and saw that 94's are rare to come with vlsd's. i would really like to have at least a rear vlsd for the winter. will something like this http://cgi.ebay.com/ebaymotors/JDM-SUBA ... enameZWD1V
fit into the r160 housing?
can i use a r200 vlsd instead since i have one off of my s13 with shafts?
5sp 94 ss
wildacex187
i know i should have started a new thread but i searched and couldnt really find an answer. can i use a scanner tool to read the check engine code without having to resort to the black and green connectors?
5sp 94 ss
- quasi-mod-o
greg donovan
start with the return spring.wildacex187 wrote:wow thank u so much. u think i should get the upgraded knuckle bushing? 80 bux is kinda steep, how much was it at the dealer?
it is the cheapest option. and if it solves the problem? awesome. if not? you are only out 1.50. and you have a new spring.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
wildacex187
greg donovan
wildacex187
ok so i did the bushing and the spring. it helped one cuz i didnt even have a spring there lol. anyway its a lot better BUT i still have a slight prob. when the car is in gear i can still move the shifter from side to side. how can i stop it from moving from side to side while in gear?
5sp 94 ss
