Hi everyone,
K so heres the rundown. I had a 1991 sports sedan that i picked up for cheap and enjoyed it and then sold / traded it... now 6 months lator i finaly find another one i pick it up for 1200 bucks. And i dont think thats such a bad deal. only has 140k miles on it. however after buying the car i find out the block is cracked i did heads on the car and its still mixing coolant with oil so dam. And i would like to biuld a monster awd turbo car.(wouldnt we all) so i dont know if this is going to be repairable or not id just asume not unless you guys think differntly. So i have a ej22t fully closed deck block in there now. what other blocks will fit and who has a good turbo longblock that will bolt on in for sale for a desent price?
Also at the same time i am rebiulding a 5 speed tranny to do a auto to 5speed conversion so i am looking for parts for that. So if u have any of the following for sale that will fit my car please pm me with price's
clutch
flywheel
manual driveshaft
manual starter
clutch pedal asembly
shifter + linkage
etc etc
hopefully you guys on the NW form will be able to help me out with parts thanks.
cracked block what do you guys think i should do????????????
dscoobydoo
did you tear down the block, or are you assuming you have a crack?
Remember the 91's have the oil/coolant cooler and if that has issues, they will mix.
Search for Jake's thread on that.
Double check before you throw in the towel.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
douglas vincent
ok, well im looking at the pic here, and its a bit confusing is it the lines that go into the side of the oil filter asemby or is it that hose that it just before the oil filter asemby can u get me a better pic or explane it a bit better thank you for all your help you guys. also what do you mean by i dont have to use it??? can u just block it off or something lol.
ferrari494
