bc5 legacy diff?
wildacex187
bc5 legacy diff?
Post by wildacex187 »
hey i came upon this online. was wondering if it will just bolt on to my 94 ss. it is stated as being a jdm bc5 legacy lsd from a 91
5sp 94 ss
wtb: power antenna, a rear right abs sensor and a rear lsd bolt on diff . pls pm me if u have these parts
PhyrraM
Post by PhyrraM »
It's very unlikely to be the proper 3.9:1 ratio.
If you can source the proper trans, it should bolt in just fine.
You could swap your 3.9 ring and pinion into this also.
I am pretty sure it is different gearing. Doesn't the ring and pinion from your old diff still work in that one?
wildacex187
wat would the gearing be? i'll give up a little off the line accel for a lsd :)
5sp 94 ss
n2x4
Post by n2x4 »
It's probably got 4.11's. Maybe 4.44's
You'd have to give up more than just a 'little off the line' if you want this LSD. Different tranny with the correct gears, or change the ring and pinion (not sure if that will work). You can't run different gear ratios in the front and rear.
SUBARUEHS Racing
wildacex187
the way to tell wat gear ratio it is is by check the sticker. i asked them for a pic of the rear of the diff to see wat it is
5sp 94 ss
Splinter
Post by Splinter »
Im not sure that diff will actually work with our cars, after doing some research into various axle types and such for my own diff swap (STI R180)
Apparently that diff is a direct bolt in to a 2.5RS, and I know from practical experience that legacy axles do not physically fit into RS hubs, they're about 3mm wider
That leads me to believe that if these axles fit an RS, they will be too small for USDM legacy hubs.
smh0101
Post by smh0101 »
LOL I know where youfound that I know where you found that!!!
I almost bought that from JHOT IMPORTS on eBay lol
I couldnt be sure it would work so I didnt buy it.
