Lowering 91 Legacy L Wagon FWD
Hello everyone, I'm new here.
I just purchased a 91 legacy L wagon fwd, and I want to lower it at least 1.5 inches. What would be an inexpensive (sub $600) to achieve this? Does anyone make tapered lowering springs that will fit? Or can I change my top hats to accommodate non-tapered springs?
What top hats would i need and where can i find them?
I plan on buying some KYB GR-2 struts, and would prefer to go with new equipment vs. used.
I'm sorry if this has been discussed, I couldn't find the info i was looking for when searching. Thanks.
voodoochylde
I really would reconsider how much you wish to drop if you are planning on using KYB GR-2's or even AGX's. AFAIK, they'll not handle much more than a 1.5" drop very well.
If you want to go lower than this, I'd recommend coilovers or maybe even struts off an STi with lowering springs those struts can handle. With the STi option, though, I believe you have to worry about camber issues.
Good luck!
Good luck!
thanks!
so, there is a subaru salvager near my house. They have some springs from a 2005 wrx that i am going to buy. I will be ordering the KYB AGX struts made for my vehicle.
....so now all i need to get are the front strut mounts and upper spring perches from an 04,05,06 impreza, right? Will these impreza top hats bolt right into my car without modification?
cut the springs one coil smaller. Works absolutely great. I have run mine like this for 2.5 years now, there are no problems.
All the stories about why this is a bad idea are crap, it is fools who cut off way too much that screw it up, not the idea itself. Also I would not cut springs that are flat on both ends, or ones that have smaller coils on the end but that is not the case here.
Grind the cut part a little bit flat so the springs will fit the perches better.
I have the AGX's also and they match up well.
Do yourself a favor and rent one of the spring compressors that is the hinged type (shaped like a big clamp), god does this save time
beater_legacy
beater_legacy
