So I’ve got my EJ22T torn down and inspected, crank needs replaced do to blow out keyway, and cylinders are at the wear limit, so a bore is in order. I was looking at the .020 over forged Wiseco pistons but the price for the stroker pistons is about the same and since I gotta buy a used crank anyway... to stroke or not to stroke, that is the question?
The rest of the details on the build include: EJ25 DOHC heads, EJ20G intake & injectors (440cc), VF-24 turbo, TMIC, 3” TBE. What I’m shooting for is a good drivable street car, not monster top end power, off boost low end is important and I think the stroker idea plays right into that. I know the DOHC heads might drop a little bottom end, but the CR will stay near the stock 8.0:1 or maybe slightly higher and the VF24 is a quick spooling turbo that’s still 300hp capable. I plan to start boost at about 12psi (below fuel cut), then add EM / injectors and ramp up from there.
Your thoughts?
Gary
Any reason not to go stroker?
All_talk
If your into a full rebuild anyways and your after some low-end, the only reason not to do a stroker is the rods. You need EJ25 rods to match whatever phase crank you choose. Phase 1 has 48 mm rod bearings. Phase 2 has 52 mm rod bearings.
Phase 1 EJ25 rods are *said* to be among the weakest factory rods, so you might budget good rods into the build.
douglas vincent
Does anyone know where I can get a stroker kit?
I tried searching for one but couldn't come up with much...
Yellow '01 Kaw. ZX-7R (SOLD) :(
Gold '88 Starion ESI-R (Drift Project)
Brgndy '92 Legacy SS, Agency Power Style Headers and Up-pipe (ebay, don't stay together), Underdrive Pully, 5MT conv, mod'd WRX cold air intake and short shifter, 12.5 lb fly
all it is a phrase 1 2.5 crank and rods.createnew wrote:Does anyone know where I can get a stroker kit?I tried searching for one but couldn't come up with much...
-Max
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
douglas vincent
