FS, 1991 SS New and Used Stuff
Legacy Rally Guy
Post by Legacy Rally Guy »
For sale:
1991 Turbo Sedan Brake Rotors, both front and rear. Definitely a good replacement part, not marred!
Left Rear AWD Turbo Spindle *bead blasted, primed, painted*
-Bearing Removed, but hub is available if desired.
Ej22t Crank
Ej22t Pistons and wrist pins
Brand new Bearing kit:
Main Bearings *up-sized .001, stock crank will need machined to fit*
Rod Bearings *up-sized .001, stock rods will need machined for fitment*
Brand new Ej22t timing belt.
Stock Ej22t turbo *a little end-play, but very usable and definitely rebuildable.
Used turbo oil and water pump. *good cores or have "rebuilt/returned" for much less than brand new*
Stock used but good Ej22t crank with a set of brand new main/rod bearings that came with my Wiseco rebuild kit. I ended up not needing these, since my bearing spun on the rod and didn't damage the crank. The bearings are a size larger, so the crank will need to be machined, but any capable machine shop can do this easily. I would suggest new rings for the pistons, it didn't smoke, but still, if you've got it open that far.. might as well for a couple bucks. The timing belt isn't needed, I got one with my rebuild kit.
My engine's pistons and turbo had 180k on them, I dont know if any part is younger than the chassis.
The crank cost me $50, the bearings were $89, the belt was $93.
Be fair and it'll be yours!
I've listed my stuff I dont have room for.
Thanks,
Ken
Oh and if you need pics, I can take some this Friday.
Legacy Rally Guy
ah well, it was worth a shot... I guess I'll just build up a lil ej22e for my dads' westfalia with this stuff... :P
bepa
oil pump
Post by bepa »
are you going to need the oil pump. was wondering your price and cost of shipping to 10463 if you could tell me I may be able to buy it from you.
but if you need it I do understand. thanks for reading this and enjoy your weekend. Bepa
91 SS/ 01 MB ML 55
Bronx, NY.
Legacy Rally Guy
Re: oil pump
bepa wrote:are you going to need the oil pump. was wondering your price and cost of shipping to 10463 if you could tell me I may be able to buy it from you.
I'm pretty sure I sent a pm earlier this week.. :P if not, let me know, it's still for sale
