For sale:
1991 Turbo Sedan Brake Rotors, both front and rear. Definitely a good replacement part, not marred!
Left Rear AWD Turbo Spindle *bead blasted, primed, painted*
-Bearing Removed, but hub is available if desired.
Ej22t Crank
Ej22t Pistons and wrist pins
Brand new Bearing kit:
Main Bearings *up-sized .001, stock crank will need machined to fit*
Rod Bearings *up-sized .001, stock rods will need machined for fitment*
Brand new Ej22t timing belt.
Stock Ej22t turbo *a little end-play, but very usable and definitely rebuildable.
Used turbo oil and water pump. *good cores or have "rebuilt/returned" for much less than brand new*
Stock used but good Ej22t crank with a set of brand new main/rod bearings that came with my Wiseco rebuild kit. I ended up not needing these, since my bearing spun on the rod and didn't damage the crank. The bearings are a size larger, so the crank will need to be machined, but any capable machine shop can do this easily. I would suggest new rings for the pistons, it didn't smoke, but still, if you've got it open that far.. might as well for a couple bucks. The timing belt isn't needed, I got one with my rebuild kit.
My engine's pistons and turbo had 180k on them, I dont know if any part is younger than the chassis.
The crank cost me $50, the bearings were $89, the belt was $93.
Be fair and it'll be yours!
I've listed my stuff I dont have room for.
Thanks,
Ken
Oh and if you need pics, I can take some this Friday.
FS, 1991 SS New and Used Stuff
Legacy Rally Guy
Legacy Rally Guy
oil pump
are you going to need the oil pump. was wondering your price and cost of shipping to 10463 if you could tell me I may be able to buy it from you.
but if you need it I do understand. thanks for reading this and enjoy your weekend. Bepa
91 SS/ 01 MB ML 55
Bronx, NY.
Bronx, NY.
Legacy Rally Guy
Re: oil pump
I'm pretty sure I sent a pm earlier this week..bepa wrote:are you going to need the oil pump. was wondering your price and cost of shipping to 10463 if you could tell me I may be able to buy it from you.
