wtb coolant surge tank. GOT ONE THANX
pls guys i need the coolant surge tank watever its called. i need to get my car back on the road ASAP. please help me out
5sp 94 ss
wtb: power antenna, a rear right abs sensor and a rear lsd bolt on diff . pls pm me if u have these parts
rear abs sensor and lsd bolt
hey how you doing? did you get the sensor or the bolt as yet?
one wat to term fix your coolant reservior on turbos anyway. I have in the past on 2 occassions I have drilled out a hole into the tank being careful to drill striaght into tank. you can go to the hareware store and get a treadth nipple and hose fitting on the other. for the life of me I can't recall the corrrect new right now.
I use a tap and slowly turn it in. you use the pipe tread tap. go in and out a few times. but slow and straight as possible. One time I used this for almost the whole summer. winter was another matter.
anyway I am going up to the car and will get these this weekend. am in bronx this sunday. we could meet up if you still need these parts.
be well. bepa
be well. bepa
91 SS/ 01 MB ML 55
Bronx, NY.
Bronx, NY.
I did about the same, except I put JB weld around the fittings when I installed the fittings. It held for about a year and a half before I got around to mounting my WRX tank.
Rio Red '91 Legacy SS
He's talking about the plastic/metal tank to the top right of the spark distribuitor for SS variants, the plastic tank on N/A vehicles is not the same deal (and sits in a different location)tahiti350 wrote:I've got a plastic one from a '90 N/A sedan... a little dirty, but in good shape.
#82 M4 TRSCCA Rallycross
