Tommy
The injectors on an EJ22T as found on 91-94 Legacy Turbos sold in North America are 380 cc/min. They are considered maxed out at 85% duty cycle.
Bill Robinson
92 Legacy Turbo Sedan
<http://rd.yahoo.com/M=163100.1330039.29 ... .tf?s=2629> Classmates.com
Click here for Classmates.com
<http://us.adserver.yahoo.com/l?M=163100 ... =598677773>
Tommy's Injectors
Gary Grahn
Tommy's Injectors
What fuel pressure is that at? If you bump the fuel pressure you should be able to change the DC considerably. You can change the fuel pressure with a bigger <or rewired> fuel pump or an Adjustable fuel pressure regulator, IE; SX or Paxton. If you have an AFC, its a pretty good idea if you are running more then stock boost or have swapped turbos.
Later,
Gary
-----Original Message-----
From: William D. Robinson [mailto:vultureboy@mindspring.com]
Tommy
Bill Robinson
<http://us.adserver.yahoo.com/l?M=163100 ... =837128198>
Later,
Gary
Tommy
Bill Robinson
