Tommy's Injectors
Locked
William D. Robinson
Tommy's Injectors
Post by William D. Robinson »
Tommy
The injectors on an EJ22T as found on 91-94 Legacy Turbos sold in North America are 380 cc/min. They are considered maxed out at 85% duty cycle.
Bill Robinson
92 Legacy Turbo Sedan
<http://rd.yahoo.com/M=163100.1330039.29 ... .tf?s=2629> Classmates.com
Click here for Classmates.com
<http://us.adserver.yahoo.com/l?M=163100 ... =598677773>
Gary Grahn
Tommy's Injectors
Post by Gary Grahn »
What fuel pressure is that at? If you bump the fuel pressure you should be able to change the DC considerably. You can change the fuel pressure with a bigger <or rewired> fuel pump or an Adjustable fuel pressure regulator, IE; SX or Paxton. If you have an AFC, its a pretty good idea if you are running more then stock boost or have swapped turbos.
Later,
Gary
-----Original Message-----
From: William D. Robinson [mailto:vultureboy@mindspring.com]
Tommy
Bill Robinson
<http://us.adserver.yahoo.com/l?M=163100 ... =837128198>
Locked
