2 questions...
** How much pressure should i be running to my turbo (t3/t4 hybrid)?
** Whats the best way to restrict the oil flow, because im shooting oil out my seals and smoking up the neighborhood...
Turbo oil pressure
Arctic Assassian
You do need some sort of restrictor for the oil feed.
My old T3/T4 had fitting with a tiny hole feeding oil into the turbo.
When you think about it the restricor actually increases the pressure, but decreases the volume of oil getting into the turbo.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
well that explains it, i dont have anything restricting volume... i do understand that im not changeing the pressure, but i do need to change the volume.. the fitting i have is evidently letting in too much oilBXSS wrote:You do need some sort of restrictor for the oil feed.
dropdfocus
Where are they available at? I'll likely need one once I feed oil to my TD05-16g via the oil filter sandwich.
Jason
Not 100% sure if it is the same as Mitsubihsi (GVR4 / Eclipse) TD05s, but those have a narrowing down of the oil passage-way going to the banjo oil-feed bolt.
So if you have the correct turbo oil feed line you should not need a restrictor (as it is built into the feed line).
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
96 Impreza OBS
99 Impreza OBS-T
dropdfocus
