16 year old's legacy
tris91ricer
Title Whore
Post by tris91ricer »
I went to one of those shops and saw an 'innercooler' once. Apparently it really IS for a forced induction application --the dildo is meant to go in the freezer first!
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
dropdfocus
Post by dropdfocus »
*sigh*
That's BAD!!!!
Jason
I have to get those for my women when I overheat them. I keep a few of 'em in stock next to the ice cube trays and frozen pizzas.
Nategreat923
Post by Nategreat923 »
555BCTurbo wrote:
Nategreat923 wrote:i asked my friend to show me what it would look like with an intercooler, so he messed with it a lil, so yeah its photochop stuff
Fixed some stuff for you
thanks, ill keep that in mind next time I use those (serious not sarcasm)
i have a question. my friend said i have a EJ22 because my soob is manny, but its not turboed so i didnt think it was.
NaTeWoOt
dropdfocus
They were all 2.2 motors in the Legacy from '90-'94 reguardless if it was manual or auto, but if it's a turbo model, then it's an EJ22T. If it's N/A (nat. aspirated) then it's an EJ22.
EJ18's showed up in low end Imprezas, and EJ25's didn't show up in the Legacy until '96.
Jason
Nategreat923
dropdfocus wrote:They were all 2.2 motors in the Legacy from '90-'94 reguardless if it was manual or auto, but if it's a turbo model, then it's an EJ22T. If it's N/A (nat. aspirated) then it's an EJ22.
ohhhhh, thanks a lot. my friend thought it was a ej20.
this will be a pain in the butt question, and ive tried lookin in other posts but im a noob, how hard and expensive would it to turbo it. like whats the minimum it would be to turbo it with the smallest turbo? thanks in advance
NaTeWoOt
Nategreat923 wrote:this will be a pain in the butt question, and ive tried lookin in other posts but im a noob, how hard and expensive would it to turbo it. like whats the minimum it would be to turbo it with the smallest turbo? thanks in advance
(someone's gonna slap you w/ the search stick)
dropdfocus
Well...
You'd be changing out quite a bit to do it.
- different ECU
- different full exhaust
- different intake manifold
- different intake tubing
- different injectors (possibly optional depending on turbo size)
- turbo
- intercooler (again optional, but highly recommended)
- many misc. hoses & additional odds & ends
All said & done, you could be selective in what you pay & where you get it from and likely pay $1k or less.
Picking up a used VF-11 (stock Legacy turbo) and other tid bits wouldn't be too hard.
Use the search function and look up turbo swap, or engine swap. Browse the topic's content and remember to take everything with a grain of salt. Everyone has a different take or opinion on situations around here.
Jason
dropdfocus
BTW, look just below and to the right of your power steering res. and you'll see a casting area that shows EJ22 right on the block. The EJ20 only showed up in the JDM Imprezas and the early US market WRX's.
Jason
Nategreat923
dropdfocus wrote:Well...
- different ECU
- turbo
Ohhhh. thats exactly what I was looking for. Thanks a lottttt.
and IMO i like front mount intercoolers better then top
NaTeWoOt
dropdfocus
Until you go with a larger turbo (which requires many more supporting mods, like fuel delivery upgrades & such) you'd lose HP with a front mount vs. the top mount. The longer length of piping to the front & such would cause longer spool up times. This would take you longer to achieve the desired effect you are going for. The top mount being right next to the turbo allows for shorter spool up time. Basically you hit full boost much quicker.
Sorry, the front mount might look cooler, but it isn't the most desirable item when running stock equipment.
Jason
Nategreat923
dropdfocus wrote:Until you go with a larger turbo (which requires many more supporting mods, like fuel delivery upgrades & such) you'd lose HP with a front mount vs. the top mount. The longer length of piping to the front & such would cause longer spool up times. This would take you longer to achieve the desired effect you are going for. The top mount being right next to the turbo allows for shorter spool up time. Basically you hit full boost much quicker.
well, they say you learn new things every day. thanks for the info. yeah, i just want a small turbo (if i really do even want one) for a little fun, because this is my car for the mountain (snowboarding with friends and such) so it wouldn't be a big turbo, I'll probably keep it NA, but I just might turbo it
NaTeWoOt
dropdfocus
Glad to help out when I can.
Jason
Post by 555BCTurbo »
dropdfocus wrote: The EJ20 only showed up in the JDM Imprezas and the early US market WRX's.
And the non-US Market Legacies and Foresters
tris91ricer
Title Whore
Nate,
I'll have some stuff you would need for a turbo swap coming up in the next few months. Harness, ECU, exh, heads and intake mani, and tdo04 with TMIC. Basically, everything you'd need except the shortblock. I'll keep you posted.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
asc_up
Post by asc_up »
you know you could always just buy an ej20g with a 5m/t off of ebay for about $1k too.
my friend and i swapped one into his 95 Impreza L. It was pretty straight forward if you have a basic idea of what you're doing. The wiring took us the longest to do, but everything was done in about two weeks and for $1k, that's the biggest performance increase you can get lol.
he went from like 115hp to 240hp and 4.44 gears lol.
Nategreat923
Long time no talk to :)
I have a question. Anyone have a straight scratchless non faded right front fender for sale? Its the stock blue color. Got hit in the parking lot, just enough to dent it :/ made me realllly mad. Hit me up with some prices pleaseeeee :)
NaTeWoOt
Nategreat923
bump
anyone?
pretty please?
NaTeWoOt
Nategreat923
possible more pictures tonight or tomorrow, just for you guys =]
NaTeWoOt
dropdfocus
Yeay! I like pictures!!! :lol:
Jason
smh0101
Post by smh0101 »
And for the record... I believe the NAs were an EJ22E while the turbos were EJ22Ts (minus the (s) for non plural use, aka singular form, so its an EJ22T)... lol
dropdfocus
You are correct sir! :)
Jason
felixpjo
Post by felixpjo »
nice!
im 16 turning 17 in april and just got my 92 GX Wagon!
1992 Liberty GX Wagon
Nategreat923
Sorry guys, I sold it to get a 1990 240sx hatch, I'm plannin to do a SR or RB20 swap, I'll keep yall posted :)
NaTeWoOt
Post by SubaruNation »
Nategreat923 wrote:Sorry guys, I sold it to get a 1990 240sx hatch, I'm plannin to do a SR or RB20 swap, I'll keep yall posted :)
*ahem*
traitor :?
