boost gauge and understanding vacuum reading
Snorkus, filters, throttle bodies and intake manifolds.
ciper
Post by ciper »
Take the elbow off and let it warm up in your house?
dirtyhandssubaru555
Post by dirtyhandssubaru555 »
yeah i could do that, but i have other things i want to do while i have that elbow off so im going to wait. its been running the same since the day i bought it, so i can wait another week.
my girlfriend finaly found out that i spent more money and time on my car then her. she was kind pist to say the least.
92ss, tdo4, wrx stage 1 clutch and 9.5 pound flywheel, sti springs, k&n panel filter, desnorkus
86 gl hatchback rip
87 gl10 rip
dirtyhandssubaru555 wrote:when ever i start my car and step on the gas it sticks to 2k or so and comes down to 750 or so but it takes its sweat ass time. around 750-800 is see 14-13.5inhg
Yeah, if you're seeing that little of vacuum at idle 750-800 rpm, then you either have a leak somewhere, or other engine problems.
dirtyhandssubaru555
like a bad valve, or a dieing cylinder. would bad air/fuel mixture cause low vacuum?
86 gl hatchback rip
87 gl10 rip
bad air/fuel mixture could cause poor idle, which might cause a low vacuum, but that's pretty substantial to be just a/f mix.
Have you tried the starting fluid around the engine while it's running to look for a vacuum leak?
dirtyhandssubaru555
i think i used starting fluid but not sure. i did spray something around the intake runners, tb, and all along the intake system and i didn't hear any changes in the engine. i do have a very rough idle
86 gl hatchback rip
87 gl10 rip
