94 Legacy part out
94 Legacy part out
I have the turbo and pipes.
Alternator and starter.
New front strut in the trunk and the other new one on the drivers side front that can be removed.
I have pending deals for the transmission and rear sway bar assembly.
Windshield, fenders, front bumper, sun roof---no good.
Most everything else there except the engine.
I do have the grille pictured farther down the thread.
Ben
Berwick, Pa 18603
Ben
Berwick, Pa 18603
I should be able to get that for you. I need a couple of days because the car is outside in the snow storm right now.vrg3 wrote:If you can get the ABS sensor out of the front driver side hub (the sensor pickup, not the toothed ring), I'd like to buy it.
scuzzy might be interested in the turbo pipes.
Ben
Hi Ciper,ciper wrote:ECU and Harness still intact? MAF and intake piping still available? Any parts from above the engine left? (intake parts, injectors)
Does anyone know how heavy the factory downpipe is?
ECU is still in the car. I removed the engine so nothing was cut. Intake and injectors are still on the engine. I am going to rebuild it and stick it in an airplane so I won't be using any of that. Tell me what you want and make an offer.
Thanks!
Ben
Car in garage and found the grille
I found the grille in the trunk! Nothing appears to be broken. I'm not sure what the bottom grille is in the picture, but it is for sale, too. The grey one isn't as nice because of the faded paint.
The unknown grille has all of the plastic pins broken on the bottom row.
I will take more pictures of either one if you are interested.
I have the car in the garage to get all the parts that were requested. If anything else is needed, please let me know.
Thanks!
Ben
Thanks!
Ben
Hi Jamal,jamal wrote:I don't think they come apart. If they do then the lens is all I'd need.Freepistol wrote:Hi Jarnal,jamal wrote:Left rear turn signal to 90220?
Driver's side rear turn signal looks good. Is it just the lens you need or does it come as one unit with the light holder?
Ben
I have the turn signal unit for you. The bulb plate comes apart from the lens. Do you still need it?
Ben
Yep, I have that.pankopp wrote:hey do you still have the adjuster that is used to adjust the Alt. up and down to tighten the belt>? I need the part that you tighten or loosen to move the whole assembly up and down. Mine has a broken bolt in it that will not come out.
Let me know!
What's your zip code?
I'm 18603.
Ben
Automatic or manual? If maunal, interested in the tranny & full pedal assembly.
Also interested in the stock trunk spoiler.
BTW, I can pick up the parts since I'm only like 30-35 miles away.
Jason
