Removing Engine from Transmission
I tried searching but no luck. I am trying to pull the engine out of my 92 Legacy, it is an automatic, and I cannot find anywhere to access the flywheel bolts to remove the transmission from the flywheel. I really do not want to pull them both if I do not have to. Am I missing something really obvious?
Confused
Saskatoon Subaru
There's a cover you can remove to get access to the torque converter bolts, which separates the engine from the transmission, i'll go take a picture its kinda hard to explain cause it is obvious. Took me a bit to find it too.
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
Saskatoon Subaru
This photo is from one of douglas vincent's posts, i circled the torque converter cover
remove the cover and spin the crank with the pulley bolt to turn it to gain access to the bolts. Hope that helps
IronMonkeyL255
Occasionally that cover will be missing. It is likely behind the flex plate. That's where I found mine...
Rio Red '91 Legacy SS
Arctic Assassian
Saskatoon Subaru
Saskatoon Subaru
Bheinen74 wrote:what do you do when the engine is seized and need to remove it from tranny, cannot turn crank pulley to get to flexplate bolts/torque converter
hmmm, that could be a challenge, if it is really "seized" how to you plan on getting the piston pin's out to crack the block?
all i need to do is save the auto tranny, the block is to become a scrap piece of aluminum. I might like to separate the block halves just to get some knowledge and experience on doing so. another engine will be taking this ones place if i dont sell the car.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Arctic Assassian
Does it have oil in it? If not, pour oil in it and break it loose the other way. My friend and I ran out of oil in a 94 na legacy on our way to fairbanks, we were 200 miles away. We poured in some oil we got from a passerby, and then took a breaker bar, turned the motor the opposite direction, and fired it right up. He put another 25000 miles on the motor.
Kickin' it old-school.
If you can get the engine forward enough, the attached torque converter will slide out of the transmission. I'd guess that it needs to come out at least 10". I would definately replace the front oil seal on the trans after stressing it out like that also.Bheinen74 wrote:what do you do when the engine is seized and need to remove it from tranny, cannot turn crank pulley to get to flexplate bolts/torque converter
You will need to remove the radiator and the trans dog bone. I would also suggest jacking up the front of the trans to help get the angle you'll need.
Since the engine is scrap, you could also try to pull the spark plugs and get some diesel or kerosene in the cylinders, leave it set for a few days, then try to break it loose.
[size=75]-97 Legacy (ain't never gonna die)
-92 SVX (attention whore)
-86 Brat (more fun than the SVX)
-92 SVX Racer (lightest SVX)[/size]
update.
i was able to turn the crank pulley backwards, so it isnt seized, just stuck at the point where the rod is jamming up thru the top of the block
i bet if i can pull out the obstuction, it might even still run.
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
