Tip's for first start after a rebuild, anyone?
Saskatoon Subaru
Post by Saskatoon Subaru »
so im just about the finish my rebuild of my 90 ej22 and i'm wondering if anyone has any tips of things a should do and watch for on the 1st start.
also i could someone tell me which is longer the number 3 spark plug wire or the number 1 i got them confused and theres no numbers on them.
thanks
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
Arctic Assassian
Post by Arctic Assassian »
Three should be longer.
Disconnect the coil.
Crank for ten seconds.
Connect coil.
Start motor.
Break in motor.
Watch out for spraying fuilds, lose clamps, vacuum leaks,and a nasty idle. if the idle is bad, drive till chck engine light comes or 10 miles, then check the code.
It should work fine.
Kickin' it old-school.
douglas vincent
Post by douglas vincent »
disconnect ignightor, fuel injectors.
Then crank for 20 seconds. The oil light will NOT turn off.
Repeat 4-6 times. Until the oil light turns off while cranking. then hook up ignightor and injectors and it will fire right up.
Saskatoon Subaru
ok, thanks, i just gotta hook up the exhaust, upper lower rad hoses, and finish putting the intake in, and hopefully i get it running today.
