Build Journal Break-in Period - Candidates Needed!
Because of some suggestions made by member in this thread:
http://bbs.legacycentral.org/viewtopic.php?t=35151
This forum has now been created:
http://bbs.legacycentral.org/viewforum.php?f=25
Rules are relatively simple and will be enforced.
Now I need suggestions and candidates for threads.
Legacy Central
Canidate #1!
06 RS block
STI crank
I-beam rods
JE pistons and rings 99.5 bore
1997 EJ20R heads and intake manifold
550 injectors
One piece WRX exhuast manifold
T3T4 Ebay turbo, internal wastegate
Ebay FMIC, GIANT with stainless tubing
PP6 for tuning. ECU may end up being early WRX with coil on plug.
Pictures in the future.
06 RS block
STI crank
I-beam rods
550 injectors
candidate # 4
I'm in... Right now I'm just in the restoring to good shape stage, but the power and suspension ought to start in the next few weeks.
I'll chip in here as well.
When I get the car.
Next year some time.
We are installing a Haltech E8 now, just to try and get it operational. I think I'm getting bent over a bit, but not much I can do about it; the car is 150 miles away...
New STI shortblock 0-mile
Legacy RS-RA heads, top end, exhaust
TD-05-16G
When I get the car.
TD-05-16G
Jerry
How's the E8 install going? Are you doing the work, or is someone else?Aerotech wrote:I'll chip in here as well.
When I get the car.
Next year some time.We are installing a Haltech E8 now, just to try and get it operational. I think I'm getting bent over a bit, but not much I can do about it; the car is 150 miles away...
TD-05-16G
umm quick question? how did it take a year to reassemble a engine?m44offroad wrote:I would say I'm in except after taking 1 year to reassemble the engine I have my doubts there would be an update more than once a year
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
The first six candidates can create their build thread.
Go for it.
Go for it.
Legacy Central
i work as a toyota tech and i pulled the motor and disassembled it last spring when we where slow and finely got time to reassemble about a month ago because we where slow.Saskatoon Subaru wrote:umm quick question? how did it take a year to reassemble a engine?m44offroad wrote:I would say I'm in except after taking 1 year to reassemble the engine I have my doubts there would be an update more than once a year
BTW who are 5 and 6
1990 AWD Legacy LS, 5mt, manual belts and Vikash standalone scantool.
Um my username isnt binarySubaruNation wrote:5 is smh01011011001101111101000000101011
6 is the person after that that dibs...'d
The numbers are the first year I got an email account... 2001 just repeated and smh is my initials.
ON TOPIC
Thanks Dave, I posted. Kindof a cool idea if I do say so myself! Especially with no other (off topic) posts allowed... much less cluttered.
If you have content ready to put up and an ongoing project that you'll update regularly, just PM me and I'll add you to the group.
Legacy Central
Give me more info The Legacy. Sounds like a nice project.
Legacy Central
I was wondering if I could get a build Journal started? I know I am noob here, but I have a pretty good build going on with Lots of pics. I have it posted on NASIOC, but those guys dont really seem to care much about anything that isnt a wrx or STi.
car:94 Lego Wagon RS Turbo Automagic
engine: built 22t, forged internals, EJ25 heads, intake, PP6 EM, ARP studs, etc
this will be a good build and should be completed in about a month or two. It will also be recieveing some suspension goodies, and brake work.
Thanks for the consideration.
-iluvdrt
-iluvdrt
98 LGT wagon auto
PNP heads, wrx 5 spd conversion, sti struts, whiteline suspension, 4/2 pots, lots more
05 impreza wgn stock
Can you link to your post on NASIOC?
Will take you into serious consideration.
Legacy Central
