Yeah, they run decently with 440's...I have observed a much richer AFR at idle...but that's about it...
Funny enough, the factory 2.2 ecu is able to effectively trim 444cc, so the 440s are just squeaking by.
TD05-16g
Yeah....you need to put an L shape hose or something there. I used an old n/a IAC valve hose.
Not off the top of my head, but you can search the parts catalog yourself
http://bbs.legacycentral.org/viewtopic.php?t=30531
If you have problems finding it in the catalog, let me know.
Crap....your right. I did use a turbo IAC hose.
Sorry about the confusion.
