crossed terminals,,,SOLVED
Dopie me...
+ on - .... big spark
no signs of life ... ie.. no lights on dash or dinging.
tried another battery ..nothing
changed main breaker ... nothing
this is a 96 corola..
any suggestions (aside from a brain transplant)
what to do, where to look
an
an
Last edited by subaru legacy turbo on Tue May 06, 2008 10:31 pm, edited 1 time in total.
93 legacy auto
93 Legacy turbo 2.0
97 SVX slotted/drilled rotors Ceramic pads
93 Legacy turbo 2.0
Does anything at all work - headlights, etc.? If no, it's probably just the fusible link as mentioned above.
100 amp
The 100 amp fuse was toast,,, Tried to remove it.
NO luck, finaly broke it up to be able to pinch the fuse wire together..
Had a bit of buzzing with the ecu & engine fuses.
tapping them got rid of the buzzing,,,
BUT,,still no indication of power no dash, interior, exterior lights..
next suggestion
(main puter smoked?)
next suggestion
93 legacy auto
93 Legacy turbo 2.0
93 Legacy turbo 2.0
ggod thought
I'll ask the mod to move it
93 legacy auto
93 Legacy turbo 2.0
93 Legacy turbo 2.0
He was being a smart ass.asc_up wrote:Huh?Redlined wrote:1) Open hood
2) remove radiator cap
3) drive a Subaru Legacy under the cap
4) install Radiator cap
Problem solved
The main fuse may be bolted in. I had an issue like this in an RX7 and was pulling on the fuse for a while before i noticed two covers for some 10mm bolts attaching the battery main to the fuse box.
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
91 SS AT
SOLVED
yes ,, correct,,, it was bolted in.. R&R ($13) started immeadiatly..
no need to take off the rad cap...
I'll just get back to installing the FMIC on my 93 turbo 2.0
Regards to all
Ian
Regards to all
Ian
93 legacy auto
93 Legacy turbo 2.0
93 Legacy turbo 2.0
