crossed terminals,,,SOLVED
subaru legacy turbo
Post by subaru legacy turbo »
Dopie me...
+ on - .... big spark
no signs of life ... ie.. no lights on dash or dinging.
tried another battery ..nothing
changed main breaker ... nothing
this is a 96 corola..
any suggestions (aside from a brain transplant)
what to do, where to look
an
Last edited by subaru legacy turbo on Tue May 06, 2008 10:31 pm, edited 1 time in total.
93 legacy auto
93 Legacy turbo 2.0
97 SVX slotted/drilled rotors Ceramic pads
stipro
Post by stipro »
Pop the cover off of the realy box under the hood and check the fuseable links. You probably burned one out with that oppsy :)
Does anything at all work - headlights, etc.? If no, it's probably just the fusible link as mentioned above.
Saskatoon Subaru
Post by Saskatoon Subaru »
i've blow en a fuseable link, and that sounds like what happened.
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
subaru legacy turbo
100 amp
The 100 amp fuse was toast,,, Tried to remove it.
NO luck, finaly broke it up to be able to pinch the fuse wire together..
Had a bit of buzzing with the ecu & engine fuses.
tapping them got rid of the buzzing,,,
BUT,,still no indication of power no dash, interior, exterior lights..
next suggestion
(main puter smoked?)
93 legacy auto
93 Legacy turbo 2.0
Richard
Post by Richard »
Maybe this isn't the best place here to post a situation like this. It is possible that those with the most knowledge and help do not frequent the "misc" portion as much as the "electrical" one.
subaru legacy turbo
ggod thought
I'll ask the mod to move it
93 legacy auto
93 Legacy turbo 2.0
Redlined
Post by Redlined »
1) Open hood
2) remove radiator cap
3) drive a Subaru Legacy under the cap
4) install Radiator cap
Problem solved
asc_up
Post by asc_up »
Redlined wrote:1) Open hood
Problem solved
Huh?
Problem solved
Huh?
He was being a smart ass.
asc_up
Post by asc_up »
Ah gotcha. I don't know why I didn't understand that earlier.
Threshld1
Post by Threshld1 »
The main fuse may be bolted in. I had an issue like this in an RX7 and was pulling on the fuse for a while before i noticed two covers for some 10mm bolts attaching the battery main to the fuse box.
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
subaru legacy turbo
SOLVED
yes ,, correct,,, it was bolted in.. R&R ($13) started immeadiatly..
no need to take off the rad cap...
I'll just get back to installing the FMIC on my 93 turbo 2.0
Regards to all
Ian
93 legacy auto
93 Legacy turbo 2.0
