Tims DOHC head swap and engine rebuild
You're blocking off the IAC? I know you can block of EGR, but I wasn't aware you can eliminate the IAC... :?s
Very nice looking shop BTW. I am EXTREMELY jealous!!!
Jason
Havnt updated the thread in a while, I got my pistons, and got my block bored and now I am just waiting for the block to get back (its getting assembled by a subaru tech)
I have the car painted flat black for now, and will be picking up a maf translator pro for management...
pics soon!
pics soon!
Tim
93 Legacy SS Winestone 5mt swapped
Megan Racing Bellmouth 13psi
WRX Intercooler and Hoodscoop
JDM ej20G DOHC head swap, wiseco pistons and td04 in the making.
As I understand ANY Subaru EJ head will bolt up to ANY Subaru EJ block - but I'd think you'd have to use the H/G to match the block as the bores change with the displacement (I think WRX = 92mm pistons, while a 2.2 = 97mm pistons).
If you use the US WRX heads you'll need to do something for E/M as the trigger points on the cam gears are supposed to be different which will not allow it to start-up on the ej22t ecu.
To have a DOHC start on a ej22t ECU the heads have to be older versions like DOHC 2.5, EJ20G, EJ20H, EJ20K, EJ20R heads.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
Yes, you need a headgasket with the proper bore size. Also, paying attention to the thinkness is important on the 22T, sicne the pistons protrude past the deck by about .020".
You cannot just slap on WRX heads and go, as the triggeres are different between phase I and phase II motors.
Lastly, do some looking around the boards. Not just here, but places like nasioc are good resources. Anything you can think of has been covered many times over.
