WTB: TDO4 turbo
94legacy2.2
WTB: TDO4 turbo
Post by 94legacy2.2 »
Im looking for a stock wrx turbo. Lines would be good with it but arent needed.
Let me know if you have one
Tyson
im slow---Location:Colorado
Got squirt? http://www.msextra.com/index.php
Blackbart
Vendor
Vendor
Post by Blackbart »
I have the td04 turbo with an 06 WRX IC and fittings, this is a bolt up to our ej22t's. $225 shipped.
94legacy2.2
Blackbart wrote:I have the td04 turbo with an 06 WRX IC and fittings, this is a bolt up to our ej22t's. $225 shipped.
All I need it the turbo. Will you sell the turbo seperate from the IC?
Blackbart
Vendor
Vendor
Post by Blackbart »
Yeah, I can do that
smh0101
Post by smh0101 »
How is it bolt in without the 90* intake?
Blackbart
Vendor
Vendor
Post by Blackbart »
smh0101 wrote:How is it bolt in without the 90* intake?
If you use the the included TMIC there is no need for the 90* elbow.
Drops right in.
smh0101
Post by smh0101 »
I'm not talking about the charge pipe... The part I'm talking about is the intake INTO the turbo...
BXSS
Post by BXSS »
I think folks use rubber hose of some sort for the inlet (? radiator or silicone 90* hose section) that should not be a big deal.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
94SS_Canada
Post by 94SS_Canada »
I used an ABS elbow, No clamping no leaks it works amzing, although it did need to be shaved a little bit
No kinks!
And It is basically a Direct bolt in although stock coolant lines have a metal bracket holding them apart for that VF you just need to cut them, it takes about 30 seconds.
FastRust
joshw02
Post by joshw02 »
please check your pm. I'd like to buy this setup.. Thanks..
94legacy2.2
Bump still looking for the turbo.
I havent heard from Blackbart so still looking
94legacy2.2
bump.
still need one please
