Moderators: Helpinators2 , Moderators
94legacy2.2
Posts: 212 Joined: Tue Aug 14, 2007 3:36 am
Post
by 94legacy2.2 » Fri May 16, 2008 4:42 am
Im looking for a stock wrx turbo. Lines would be good with it but arent needed.
Let me know if you have one
Tyson
im slow---Location:Colorado
Got squirt? http://www.msextra.com/index.php
Blackbart
Vendor
Posts: 1722 Joined: Fri Mar 05, 2004 1:31 am
Post
by Blackbart » Fri May 16, 2008 12:35 pm
I have the td04 turbo with an 06 WRX IC and fittings, this is a bolt up to our ej22t's. $225 shipped.
94legacy2.2
Post
by 94legacy2.2 » Mon May 19, 2008 2:55 am
Blackbart wrote: I have the td04 turbo with an 06 WRX IC and fittings, this is a bolt up to our ej22t's. $225 shipped.
All I need it the turbo. Will you sell the turbo seperate from the IC?
Blackbart
Vendor
Post
by Blackbart » Mon May 19, 2008 2:59 am
Yeah, I can do that
smh0101
Posts: 3056 Joined: Wed Jan 18, 2006 7:56 am
Post
by smh0101 » Mon May 19, 2008 3:37 am
How is it bolt in without the 90* intake?
Blackbart
Vendor
Post
by Blackbart » Mon May 19, 2008 1:22 pm
smh0101 wrote: How is it bolt in without the 90* intake?
If you use the the included TMIC there is no need for the 90* elbow.
Drops right in.
smh0101
Post
by smh0101 » Mon May 19, 2008 2:48 pm
I'm not talking about the charge pipe... The part I'm talking about is the intake INTO the turbo...
BXSS
Posts: 1301 Joined: Wed Jan 10, 2007 4:23 pm
Post
by BXSS » Mon May 19, 2008 4:29 pm
I think folks use rubber hose of some sort for the inlet (? radiator or silicone 90* hose section) that should not be a big deal.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
94SS_Canada
Posts: 851 Joined: Mon May 12, 2008 4:19 am
Post
by 94SS_Canada » Mon May 19, 2008 9:12 pm
I used an ABS elbow, No clamping no leaks it works amzing, although it did need to be shaved a little bit
No kinks!
And It is basically a Direct bolt in although stock coolant lines have a metal bracket holding them apart for that VF you just need to cut them, it takes about 30 seconds.
FastRust
joshw02
Posts: 89 Joined: Sat Mar 22, 2008 6:45 am
Post
by joshw02 » Wed May 21, 2008 2:22 pm
please check your pm. I'd like to buy this setup.. Thanks..
94legacy2.2
Post
by 94legacy2.2 » Wed May 21, 2008 4:28 pm
Bump still looking for the turbo.
I havent heard from Blackbart so still looking
94legacy2.2
Post
by 94legacy2.2 » Sat May 31, 2008 7:39 am
bump.
still need one please
