I found a Legacy with 78k miles on for only $500 locally. Has perfect engine and body, but with minor transmission issue.
Everything works but gear won't go into reverse easily at times. Do you think this may turn out to be a major issue later on? Would replacement of transmission oil help this out?
What could potentially cause this kind of issue?
Your input is appreciated.
Thanks,
Tim
I may pick up 92 Legacy 2.2L with minor transmission problem
02 WRX 282whp VF34
Reverse is commonly hard to get into. I often just shift into a forward gear, then try reverse again. Common!
