94 touring wagon/auto trans/difficulty in to reverse/also no
drums
Post by drums »
ise...
feels like the thing that detects that the brake pedal is in is dirty...
gotta pump the brake (working to find the release) for it to engage the button on the shifter. shifts smoothly once engaged.
i assume this is in the handle itself...could it be something in the brake pedal?
also, there is a little bit of a whirring sound when pushing a bit (higher rpm/ up to highway speed)
this is from a test drive.
they think the whir is from ...i think they said "check ball"(something like this, i thinkit has to do with fluid/pressure) once engine is warmed up sound is less prevalant...cold starts and it is more audible.
any similar experiences?
shifts fine. noise comes from the rear not all the way back though.
thanks!
drums
Post by drums »
one more on this one...rather than starting a separate thread..
do these thing pul a little to one side when accelerating
when letting go of the wheel and stepping hard it pulled to the right a bit...
nothing dramatic...just a little pull to the right.
ciper
Post by ciper »
I bet the shifter and lock out solenoid need lubed.
Without hearing the whir sound my first guess would be a wheel bearing.
drums
Post by drums »
ciper wrote:I bet the shifter and lock out solenoid need lubed.
it isn't a pulsing whir...doesn't sound like bearings i've had go bad in the past with other cars...but maybe?
it is only audible when accellerating.
