feels like the thing that detects that the brake pedal is in is dirty...
gotta pump the brake (working to find the release) for it to engage the button on the shifter. shifts smoothly once engaged.
i assume this is in the handle itself...could it be something in the brake pedal?
also, there is a little bit of a whirring sound when pushing a bit (higher rpm/ up to highway speed)
this is from a test drive.
they think the whir is from ...i think they said "check ball"(something like this, i thinkit has to do with fluid/pressure) once engine is warmed up sound is less prevalant...cold starts and it is more audible.
any similar experiences?
shifts fine. noise comes from the rear not all the way back though.
