emanage ultimate...
mxpunk
emanage ultimate...
Post by mxpunk »
Any of you guys look into the eManage ultimate for tuning your NA-T-legs, or even factory t-legs?
It allows for direct control over your injectors via IDC and not ghetto ways such as MAF..
Just curious cause' I see alot of people talking about FMU's and whatnots..this isn't the 1990's anymore..and since all of you legacy guys are probably obd-1, the EMU is almost like a stand alone since it offers timing control too (sort of) along with a countless array of other options..
1996 Impreza Outback Sport 5 speed ej22
1997 Impreza Brighton 5 speed ej18t
Re: emanage ultimate...
Post by SubaruNation »
mxpunk wrote:Any of you guys look into the eManage ultimate for tuning your NA-T-legs, or even factory t-legs?
you can't have a normally aspirated turbo legacy
James614
Post by James614 »
I think he meant a turbo'd Legacy that came N/A from the factory (and presumably running the N/A ECU with FPRs and whantnot to keep it from blowing up).
What do you mean controlling the injectors via IDC? Is this just a piggy-back fuel/timing controller?
keirnna
Post by keirnna »
The emanage ultimate is a full fledged stand-alone ECU. I have never heard anything good about the emanage except from people that had Greddy balls deep in their mouth.
I have heard that the emanage ultimate allows more resolution that say a Power FC, but even here in Japan a Power FC is the way to go.
Subarus are probably the most reliable cars made – they make Hondas look like South American dictatorships." - Jeremy Clarkson
BXSS
Post by BXSS »
The E-manage Ultimate does have Alot of nice features.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
keirnna
Post by keirnna »
BXSS wrote:The E-manage Ultimate does have Alot of nice features.
What does it require to tune it? A Greddy authorized tuner?
James614
Post by James614 »
I'm assuming they stopped making the harness for BC/early GC applications, cause the ones on their site don't look like they'll work.
ya i knew what you meant, just thought i'd point that out :)
mxpunk
Post by mxpunk »
they do make hanress' for jdm ej motors but you can just wire it in as it IS universal
it requires a laptop and a wideband just like any other piggyback sort of..it has its own software. and i meant for people with NA legacys that want to booost them.
mxpunk
Post by mxpunk »
James614 wrote:I think he meant a turbo'd Legacy that came N/A from the factory (and presumably running the N/A ECU with FPRs and whantnot to keep it from blowing up).
Alot of piggybacks use MAF signal to -/+ fuel but the EMU lets you control them directly (pulse width) so it doesnt effect timing if you add or remove fuel. The Blue eManage allows similar control over the injectors but it does not allow you to subtract fuel directly, only add it. Atleast thats what mine does..
douglas vincent
Post by douglas vincent »
I am finally looking into emanage....
I have wanted to do a proven 11.99 or better and/or 400 whp dyno chart with the PerfectPower6 but have been thwarted repeatedly, but not by the PP6, but it has most likely been the end death of a few or more high hp motors.... :(
mxpunk
Post by mxpunk »
douglas vincent wrote:I am finally looking into emanage....
dude..you ARE crazy. i would be crying if i built and busted as many motors as you but props to you for being a pioneer!!!
keirnna wrote:The emanage ultimate is a full fledged stand-alone ECU. I have never heard anything good about the emanage except from people that had Greddy balls deep in their mouth.
The emanage ultimate is not a stand alone ECU. It is a piggy back ECU.
keirnna
Post by keirnna »
I knew the standard emanage was a piggyback, but I thought the ultimate was a standalone. Learn something every day...
From the brief reading I've done, it's very close to being a stand alone...seems to have a decent amount of features, but still is a piggy back though.
PhilSine
Post by PhilSine »
I Know this thread is a few months old but since I'm new to this forum I feel I should chime in.
I've been using the E-Manage Ultimate on my 98 OBS-T for over a year now and it has been great. Prior to adding the turbo to my car I had very little experience with anything newer than a 77 Jeep. I'm not an idiot, I just never had the inclination to get into modding cars. Then again, I never owned a car worth modifying before either so it was more a matter of circumstance.
ANyways...
The EMU has been great and even a tuning noob like I was had a relatively easy time wiring it up and programming it. The auto-tune function takes almost all of teh guess work out of setting up a base map and its easy to turn it off once you get that base map and fine tune from there. I run about a 14.5:1 AFR cruising and 12:1 AFR at full boost (7.5 psi for my car).
With the new car (91 SS) I've been wondering how I was going to have to approach EM and from what I've read, I'm starting to consider using the EMU for it.
I'm looking to get 400 whp but am very patient and not afraid of research and new ideas. I spend my money wisely so I don't have to be bothered with buying the wrong parts.
I'm not afraid to tackle a full stand alone even if I have to wire the entire thing in myself. I just want to get the most out of my car without breaking my bank or my engine. Also, I was an electronics technician in the Coast Guard and then as a civilian for a total of 7 years in the industry which has greatly aided my ability to play with wires.
91 Legacy SS
98 OBS-T
Good to know that EMU is working well in your 98 OBS. If you put in your Legacy, do keep us updated.
400whp with a piggyback system like that will be challenging. Granted standalone systems are a good bit more expensive, but their flexibility cannot be matched by any piggyback. There will always be certain issues when trying to trick the stock computer.
If you can do it and maintain good drivability then more power to you.
BXSS
Post by BXSS »
I'm getting a similar more HP itch with my OBS-T, & was thinking about running a built ej22t shortblock (I have 3 ej22ts in my garage) with a set of phase II 2.2E heads (HUGE PORTS compared to a PI 2.2), USDM WRX intake manifold with TG delete / modded injectors, Garrett GT turbo between a GT2871R-GT32.
I was planning on using a Hydra as they have a plug in version for newer 2.2s, but that would mean going back to stock for inspection (OBDII plug-in inspection in NYS - no inspection = no registration).
If the EMU could do this it would be nice (no need to take the car apart once a year for inspection).
I have to get all the junk I have for the car on it & hit the track with the stock N/A-t motor before I even think of upgrading.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
