Need help with wastegate to MBC vaccum line.
dsm_luck
Post by dsm_luck »
Hi, I was working on my car today and I noticed that in the instructions in the library for the halman mbc, that your supposed to have a small brass fitting with a hole in the mbc to wastegate line. I do not have that and come to think of it the lag between shifts has always been pretty bad. What can I do to fix that? Is there a hardware store piece I can put in there or even just poking a hole in the line? Any ideas?
dsm_luck
Post by dsm_luck »
Im just wondering is that brass fitting a simple hole or is it a one way valve? Is it something I need to get at the dealership? I read that the wastegate cannot close between shifts without that brass fitting.
dsm_luck
Post by dsm_luck »
Can anyone give me some info on this? Is there or is there not supposed to be a brass fitting that goes on the wastegate actuator to boost solenoid line? I called my local subaru dealer and they had no idea what I was talking about. Anyone adivise?...thanks.
Its the next to last pic on the page. What is that and if I cant find it at the dealership what can I use in its place?
http://legacycentral.org/library/literature/hbc.htm
94SS_Canada
Post by 94SS_Canada »
If your not using this MBC you DO NOT NEED IT!
FastRust
Dr. Gonzo
Post by Dr. Gonzo »
Its a check valve or a one way valve. You can probably pick one up at a local hardware store. Greetings from Longmont!
04 Forester XTi VF39, TMIC, 3" exhaust, COBB accessport
92 Legacy L wagon 5 spd, 266K miles
83 wagon SOLD
04 STi COBB stage 2 & wingless SOLD
92 Legacy SS 5MT-TD04,TMIC, 3"exhaust SOLD
00 Legacy GT wagon 5spd SOLD
90 Legacy LSi wagon
dsm_luck
Post by dsm_luck »
Ok, thanks for the info. I love being back in Colorado.
kamr0n
Post by kamr0n »
93 legacy wagon. 5mt. awd. turbo.
99 toyota tacoma. 3.4 s/c 4x4 LT 5spd.
