Deleting ABS ???
Boostedballs
Deleting ABS ???
Post by Boostedballs »
I am compiling parts for my water-to-air intercooler setup and I would like to place the shurflo pump in the spot where the battery goes or where the ABS system is.
I can move the battery to the trunk but I don't want to. OR I can remove the ABS.
What all is needed to remove the ABS and have the brakes function like normal?
Air-to-Water Intercooler, VF-39, 550 injectors, AEM FIC, stainless race header, 3" stainless exhaust, 75hp Nitrous, 150psi H2O injection, intake mods, stock: long block, 4EAT, ecm.
g20sleeperjdm
Post by g20sleeperjdm »
relocate the battery.. its much easier and i'd think cheaper too
1992 Legacy SS_5spd
Put the pump under the battery, like what I did, or put it under the abs pump.
Having the pump at a low spot is a good idea.
Removing the ABS requires making a bunch of brake lines. You need to be handy with a flaring tool, and making double flared ends.
Boostedballs
ok, I decided to put the cooler and fan under the battery and the pump under the ABS unit. I had a bunch of aluminum sheet metal laying around so now it is going to good use. I'll get some photos posted when it's all done.
