Legacy details and specs
metalhead77
I'm new to the forum, and to Legacys. I just want to know some basic details of my vehicle. I'm fairly confident it is a 1994 Subaru Legacy L with a 2.2 Boxer that isn't turbocharged. However, in those details, I am sure of three. It is a 1994, it is a Legacy, and it isn't turbocharged. If anybody on this forum has details they can share, please do. Thank you.
metalhead77
I am betting on LS as well since it has a sunroof. Definitely has to be a 2.2L non turbo. Check out this site.metalhead77 wrote:How do you know for sure that it is an LS? Also, what is the engine size? Is it a 2.2 like i think, or is it a 2.0, or a 1.8, cause supposedly that option was available too. If need be, I can post pics of the engine on here for you to check. Thanks
http://www.cars101.com/subaru_legacy_ar ... 4%20Legacy
if it has sunroof its a LS i have one. if its not turboed than it is a 2.2L and if its a 94 than chances are it AWD. oh is turboed even a word. cayse i clam it if its not
metalhead77
In response to ericem, that site kind of confused me. The S's and O's, what do they stand for? In response to SILENC3R, I do not believe it is all wheel drive, but I will check again when I get it worked on and inspected. Here's another query for you all. The EJ22 (I believe that's the correct engine code), how many Legacy's, or other Subaru models, was that available in. I am speaking of the non-turbo'd version, and I would like to know model years and spec option, such as AWD and things like whether it is a Legacy (or Impreza, or Forester) L, or LS, or Sport. Thanks.
why do you need to know more then what was supplied on the link posted?metalhead77 wrote:In response to ericem, that site kind of confused me. The S's and O's, what do they stand for? In response to SILENC3R, I do not believe it is all wheel drive, but I will check again when I get it worked on and inspected. Here's another query for you all. The EJ22 (I believe that's the correct engine code), how many Legacy's, or other Subaru models, was that available in. I am speaking of the non-turbo'd version, and I would like to know model years and spec option, such as AWD and things like whether it is a Legacy (or Impreza, or Forester) L, or LS, or Sport. Thanks.
look under the car and see if it is awd.
i have never seen an LS that did not have awd.
you should see mine then.quicklook wrote:why do you need to know more then what was supplied on the link posted?metalhead77 wrote:In response to ericem, that site kind of confused me. The S's and O's, what do they stand for? In response to SILENC3R, I do not believe it is all wheel drive, but I will check again when I get it worked on and inspected. Here's another query for you all. The EJ22 (I believe that's the correct engine code), how many Legacy's, or other Subaru models, was that available in. I am speaking of the non-turbo'd version, and I would like to know model years and spec option, such as AWD and things like whether it is a Legacy (or Impreza, or Forester) L, or LS, or Sport. Thanks.
i am just missen with you and i wish it was true so i could have AWD drive funquicklook wrote:i did not say they did not make them, i said i never saw one.
metalhead77
