TD04 + TMIC + custom pipes = complete kit!
Check it out:
http://i39.photobucket.com/albums/e174/ ... 000151.jpg
Complete kit including:
TD04
WRX TMIC
MBC
custom steel intake pipe
rubber 90* boot
custom steel y-pipe
rubber throttle body hose
custom steel BOV flange
Note: TMIC not that shiny anymore.
Everything is in excellent working order and currently installed. I'm looking for $300 for the complete kit. Thanks.
Also have TurboXS FCD I'll throw in for another $50, or will sell seperate for $75. All prices plus shipping.
TD04
WRX TMIC
MBC
rubber 90* boot
custom steel y-pipe
Thanks for reminding me Dusty B! I have modified this TMIC so there is no cutting of the throttle body necessary!Dusty B wrote:I'd probably snag this if I hadn't just picked up a ported/polished tdo4. It'd still be worth buying, but I'm kind of against the smashing of firewall/cutting of tb. Good luck with sale. nice to see a whole kit for someone!
man i wish i had some extra cash for this set up.
would there need to be changes made to the fuel system if the FCD was used and the boost cranked up the optimal setting for the tdo4?
OT, would you drive up to fargo for a rallycross in mid oct if it fit your schedule?
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
I ran 16-18 psi with this setup on my SS, which I'd say is on the "high" side of optimal
with the only "fuel system mod" being a Walbro. This setup is currently on my wagon running ~12 psi on N/A ECU, turbo injectors, and the Walbro.
As a spectator, hell yeah! As a competitor, I have nothing to drive like that. My wagon is undergoing an "offroad" transformation!greg donovan wrote:OT, would you drive up to fargo for a rallycross in mid oct if it fit your schedule?
you going for the rockcrawler look now?Binford wrote:As a spectator, hell yeah! As a competitor, I have nothing to drive like that. My wagon is undergoing an "offroad" transformation!greg donovan wrote:OT, would you drive up to fargo for a rallycross in mid oct if it fit your schedule?
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
More or less.
Tubular sub-structures.......
And it's not for the looks, purely functional.
Depends on what it is, as this is tenitively pending......Spitfire999 wrote:Would you be willing to separate anything form this kit?
Ben
I could probably make up some more of the custom piping........Spitfire999 wrote:Looking for everything except the turbo and the intercooler.Binford wrote:
The 90 degree piece is a rubber hose, but the "intake" pipe I could duplicate. You'd need to tell me what size nipples, how many, and where to put them. It's been a long time since I've seen a stock setup, and I know I deleted some of those hoses on mine. I could go so far as to get the rubber 90 for you if you chose. Let me know what you need and I could shoot you a price based on that.Spitfire999 wrote:If you could make another 90 degree bend from the turbo and then that pipe that goes from that to the air box, I would be interested.
Ben
Would anyone else be interested?
+1 for the custom steel turbo, I/C and block-off piping. And, if you're buying 90* elbows, i'd be in for that too.Binford wrote:The 90 degree piece is a rubber hose, but the "intake" pipe I could duplicate. You'd need to tell me what size nipples, how many, and where to put them. It's been a long time since I've seen a stock setup, and I know I deleted some of those hoses on mine. I could go so far as to get the rubber 90 for you if you chose. Let me know what you need and I could shoot you a price based on that.Spitfire999 wrote:If you could make another 90 degree bend from the turbo and then that pipe that goes from that to the air box, I would be interested.
Ben
Yeah, I'll be doing some work on my car tonight (just shit coolant all over my driveway, I hope its just a hose gone badBinford wrote:
Forgot to post it here, I did start a new thread:
http://bbs.legacycentral.org/viewtopic.php?t=36928
So does the firewall need 'massaged'? Or does the modded TMIC take care of that too?
What's the good/bad of blocking off the PCV? Will it throw a CEL?
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
