Fill UR own mounts?
New92
Fill UR own mounts?
Post by New92 »
So has anyone tried to use the windshield urethane trick? I used it on my old neon but was curious if the results are similar on these much older chassis. I know of old school drag guys that will use nothing else and am curious if there is anybody out there using this in the ol'tleg.
Thanks.
1992 SS 5MT
ciper
Post by ciper »
Subaru sells hardened mounts that aren't very expensive. Because of it no one has had to create their own.
NuwanD
Post by NuwanD »
Works like a charm in the transmission mount since there are several voids to fill. You'll need almost one full tube to do the tranny mount alone.
Subaru engine mounts do not have enough voids to make a difference.
Nuwan
1992 Open Class Legacy Turbo
2004 Forester XT
1990 Rover Mini 1000
I need to do this for the sissy Mazda. The liquid-filled control arm bushings always felt wussy, but now the car has weird issues while cornering that can only be the problematic Ford bushings. The motor mounts are a known issue and nobody makes aftermarket urethane parts. If only Subarus didn't get so damned ugly and heavy...
n2x4
Post by n2x4 »
Like this? :wink:
Something to note, I put duct tape one one side of the mount and then squirted the window weld in. Strangely enough, after 2 days the side with the tape was still gummy. I removed the tape and waited another day. Still gummy. I used goo gone to remove the left over duct tape sticky residue and by the end of the day all parts of the mount were solid.
I don't suggest using duct tape, but try using something to make sure the poly doesn't flow out the other side.
SUBARUEHS Racing
Hocrest
Post by Hocrest »
Where are you getting this stuff? I tried looking for it a few years back, and none of the local places had it...
It probably didn't help that I wasn't exactly sure what to ask for...
Me - Yeah, I'm looking for a windshield adhesive that I can use to firm up my tranny mount
AZ guy - We have this stuff to re-attach your rear view mirror...
[size=75]-97 Legacy (ain't never gonna die)
-92 SVX (attention whore)
-86 Brat (more fun than the SVX)
-92 SVX Racer (lightest SVX)[/size]
n2x4
Post by n2x4 »
Advanced Auto has it. It's called 3M Window Weld. Comes in a caulking tube. Costs about 9 bucks.
SUBARUEHS Racing
New92
Post by New92 »
n2x4 wrote:Like this? :wink:
THanks for that tip. I think Ill try wax paper then tape that to the mount.
1992 SS 5MT
BXSS
Post by BXSS »
I did this on a few cars including the tranny mount of my OBS-t.
It works well & is CHEAP!
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
PhilSine
Post by PhilSine »
Checker/Shucks/Kragen also sells it.
91 Legacy SS
98 OBS-T
shtbxr22
Post by shtbxr22 »
evolutionmovement wrote:www.mcmaster.com
got a quicker way? there is alot o' shit there
1998 VW GTi VR6 5MT (SOLD)
greg donovan
Post by greg donovan »
my brother did this too to the tranny mount. worked pretty well.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
I've actually got some 80 durometer stuff I bought back when. If you want it, make me an offer.
