I have a 91 Legacy L AWD Non turbo,
I need a tranny.
I have found one from an impreza, P/N TZ102ZA5AA
My original is, TZ102ZA2AA will they swap? I know the Gear Ratio may be different so I may have to swap the rear diff as well, but otherwise, will it work?
I've also read that the output shaft on the tail may be different but that i can swap the tail shaft from my old trans. over to the new one.
Any advice?
Thanks,
Chris
Trans Swap/ Compatibility
If you're aware of the final drive ratio issue, I don't see any major issue why it wouldn't swap.
You may run into an issue with the pivot ball for the clutch fork, depending or not if the impreza transmission had a hydraulic clutch or not.
chriskatana
Your 91 AT AWD trans has a 4.111 final drive ratio.
Do you know the year of the impreza the transmission is coming out of?
According to the info I have the 1997 Impreza 4AT final drive ratio is also 4.111
http://www.main.experiencetherave.com/s ... f_info.pdf
