Hey,
My 92 Legacy wagon recently started leaking gas from it's fill neck. Upon inspection, it appeared that it had been patched before, and that the patch had come undone. I repatched it, and it still didn't fix the problem. Is the pipe difficult to replace? And also, does anyone know where I can obtain a replacement? Thanks!
Leaking fuel neck
Leaking fuel neck
1971 Mustang coupe, with a mod or two
1992 Legacy Wagon, bone stock, but still goin'
The filler necks are unfortunately a common spot for rust. Dirt collects between it and the plastic cover.
You can buy a new one from the dealer or get a used one from a junkyard or see if someone from the board has one.
It's not too difficult to replace.
