Question...Are OBD 1 scanning/diagnostic tools
worthwhile? If so, what can be done with them besides
clearing the CEL? I know you can get some information
as to why the code is displayed, but what value does
this have? Thanks for all the info. In the last few
weeks I have learned a lot more about my own car. I
appreciate the help.
-Brian
Do You Yahoo!?
Send your FREE holiday greetings online!
http://greetings.yahoo.com
Send FREE Holiday eCards from Yahoo! Greetings.
http://us.click.yahoo.com/IgTaHA/ZQdDAA ... /XoTolB/TM
OBD Stuff...
Josh Colombo
OBD Stuff...
Personally, OBD 1 scanner stuff probably really isn't that good an investment. With the OBD 1 computers you can check the diagnostic codes yourself, clear them, and so forth. Maybe the only other thing you would get with a scanner would be see some inputs from sensors when car is running.
Check out my site for info on how to pull the codes/reset ecu and stuff. www.surrealmirage.com/subaru/subaru.html
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com> **NEW**
of beats and rhythm" - ME
-----Original Message-----
Sent: Friday, December 28, 2001 2:17 AM
Subject: [BC-BFLegacyWorks] OBD Stuff...
-Brian
Do You Yahoo!?
Josh Colombo
-Brian
Do You Yahoo!?
Rod Grosvenor
OBD Stuff...
Brian-In addition to what Josh gave you: the scan tool will give you what is called a "diagnostic tree" to follow while attempting to eliminate any problems. It will highlight any specific codes relative to each screen you choose on the scanner. It`s very useful, expensive & usually relagated to dealerships.---ROD (AZ.)
----- Original Message -----
Sent: Friday, December 28, 2001 1:16 AM
-Brian
Do You Yahoo!?
ADVERTISEMENT
<http://rd.yahoo.com/M=216105.1806326.33 ... =posthol01>
<http://us.adserver.yahoo.com/l?M=216105 ... =142620367>
-Brian
Do You Yahoo!?
ADVERTISEMENT
milehial2000
OBD Stuff...
It probably depends on the version of OBD that you have but we are
trying several data logging systems on some later models most with OBD
2 and are having good results and getting a lot of information. You
might want to check on the web or contact me Wed. and I will give you
a few leads to try.
> -Brian
> Do You Yahoo!?
Tiny Wireless Camera under $80!
Order Now! FREE VCR Commander!
Click Here - Only 1 Day Left!
http://us.click.yahoo.com/WoOlbB/7.PDAA ... /XoTolB/TM
a few leads to try.
> -Brian
> Do You Yahoo!?
