An introduction and a question about awd
146x
Post by 146x »
Howdy folks...glad you are here. I just bought a '93 legacy wagon a/t (my second one). When I make tight slow speed turns, the car slows down and binds. (Just like my truck does when in 4wd) After I put it in park and shut it off, the car lurches a bit. The thing must be locked in a even form of awd??
Just took it to a shop and they say the duty sol. is out causing the binding. (cost $1175 to fix) Can I put a 15 amp 2wd fuse in to remedy the situation (short term)?
Thanks in advance.
Aerotech
Post by Aerotech »
Read this post;
http://bbs.legacycentral.org/viewtopic. ... sc&start=0
Are you getting a flashing power light, or codes on startup?
Welcome to the group!
Jerry
146x
Post by 146x »
Thanks for the response. The power light flashes on 16 times on startup. Any idea if the 2wd fuse would be a temporary cure?
Re: An introduction and a question about awd
146x wrote: (cost $1175 to fix)
:shock: Run away from that shop, holy rip-off batman. A decent mechanic that has ever touched a Subaru transmission wouldn't need a $1000 worth of labor to get it done.
Throw the fuse in until you can get a second (or third) opinion on it. A competent mechanic with a lift and the proper tools should not take more than 3-4 hours to do it. Even that's a stretch.
altron23
Post by altron23 »
yea its just a solenoid in the back of the tranny inside the rear housing, u can do them in the car, super easy, done it before.
-Garrett-
-subby tech-
eastside subaru
-90' legacy wagon L 2.2l 5mt swap, dumped on sti struts/springs
-88' RX-7 SE, waiting for some $ to be my track car!
