Howdy folks...glad you are here. I just bought a '93 legacy wagon a/t (my second one). When I make tight slow speed turns, the car slows down and binds. (Just like my truck does when in 4wd) After I put it in park and shut it off, the car lurches a bit. The thing must be locked in a even form of awd??
Just took it to a shop and they say the duty sol. is out causing the binding. (cost $1175 to fix) Can I put a 15 amp 2wd fuse in to remedy the situation (short term)?
Thanks in advance.
An introduction and a question about awd
Read this post;
http://bbs.legacycentral.org/viewtopic. ... sc&start=0
Are you getting a flashing power light, or codes on startup?
Welcome to the group!
Jerry
Re: An introduction and a question about awd
146x wrote: (cost $1175 to fix)
Throw the fuse in until you can get a second (or third) opinion on it. A competent mechanic with a lift and the proper tools should not take more than 3-4 hours to do it. Even that's a stretch.
