ej22t into a loyale?
has it been done yet? my dads motor in his loyale is shot and i got a spare legacy engine. im thining a new mouse inthe cage will give it a little pep.
(91 turbo sleeper to be)- RIP
I miss my legacy :(
I miss my legacy :(
As with the turbo swap on a Legacy, you have to have a turbo C/M if you plan on putting a turbo motor into the Loyale. If the Loyale is a non-turbo then you will have to replace the C/M with one out of a turbo GL or Loyale. There will be more info on the EJ22 type swap Here..... http://www.ultimatesubaru.org/forum/for ... y.php?f=29
I used to have a GL wagon that I put an EJ22 in and it MAKES ONE HECK OF A DIFFERENT CAR!!!!!!
G/L with the swap.
G/L with the swap.
92wagon (wife's)
92 sedan (sold)
91 ss no mods (sold)
88 GL Wagon (broken)
92 sedan (sold)
You can do it without swapping the crossmember but will have to be creative and build a new up pipe. But if your going to take the time to do it, find a turbo cross member and just swap it(this is what I wish I did).
It will turn the car into a different animal, and you will never want another EA-82 in it again
. Go to the USMB and look at the Subaru conversion forum, piles of good info there.
Matt
Matt
ha i figures some one had but its fun to be he first. i got a spare cross member but if i didn't id just modify the existing one i weld all day and have some fabbing under my belt. what i wold really like is to move the engine behind the front wheels and make it RRD i got a welded dif for the rear lsd would be best but budget build.
what about suspension i thinki i could use a porche koni in the rear and maybe a custom strut type for the front?
I miss my legacy :(
I miss my legacy :(
If I rember right, you cant really modify the N/A crossmember since the P/S lines and sway bar are in the way(right were you would be placing the exhaust). But I might have also just been to lazy to do it and thats why I didnt cut it up.
Matt
Matt
85 GL wagon, EJ-22T, 5MT, KKK K-26, starion FMIC, Walbro 255, RX struts and sways, rear disc, rear LSD, Megasquirt fuel only, JAW 1.3......
