In my own personal experience, those don't work good at all. I had one like that, and a GReddy catch can (the old square one) and neither worked well at all. They would catch some oil vapors, but they didn't pull the water out like they should.
If you're going to buy a catch can, make it a one-time purchase. Believe me, even though these cost more, they're worth it.
there are a few different ones out there that employ the same design and are around $100. It would be worthwhile to spend a bit more on something that actually works is all im trying to say.
94 Ti Pearl White - 191k - Tein - Rota - Dunlop - ITG
94 Mi Blue Metallic - 210k - Whiteline - Pirelli - RallyArmor - Hella - AEM
Be careful in the winter though. If you make a bunch of short trips they can ice up, blocking the ports in the catch can, and causing your motor to build pressure in the crankcase.
This happened to me, and my turbo spit out a quart of oil between the two ends of it. Its a BB Garrett, so it is still fine, but journal bearing turbos don't appreciate that so much. I also had a ton of fun cleaning all that oil out of my intercooler and charge piping. Thank goodness I didn't blow out any of my cam or crank seals. I might have been a little more upset.
I suggest you take off any catch can in the winter, so it doesn't turn your car into a smoke machine. It has happened to a few people I know. Its only an issue when you get down to the sub zero temps or below. The day it happened to me we had a high of 2°
I wouldn't use steel wool unless it was stainless. I was thinking about using some of those copper scrubbies you find in the cleaning section at the grocery store.
What do the aftermarket ones usually run inside as a filtration unit? I read in Import Tuner recently that they actually gained 2 hp on an RX-7 by installing a oil catch can.
The typical ones you see for sale everywhere are just an empty can. No baffles, no filtration, so it's basically whatever gets caught in there might stay, or it may get sucked right through to the intake like it normally would have.
2hp gain on an RX7 by putting a catch can on? that's bs. 2hp is well within any dyno's error range, so they could have seen a 2hp gain by waiting 5min and running the car again with no mods at all.
But, my point being 2hp is well within any dyno's error range, so whether it was 2 hours later or 2 weeks later, it still doesn't mean crap. You can gain 2hp by driving 10 miles to a different altitude or a different temperature.
2hp isn't worth mentioning as a "gain". That's all I'm saying.
supra90turbo wrote:But, my point being 2hp is well within any dyno's error range, so whether it was 2 hours later or 2 weeks later, it still doesn't mean crap. You can gain 2hp by driving 10 miles to a different altitude or a different temperature.
I agree. There's no way you gained power with a catch can.
'92 Legacy Sport Sedan - EJ22T, 4EAT, AWD - Snorkle Delete, Custom Grounding, 3" Catless TBE.
Could the HP gain come from the fact that oil isn't being sent through the intake and into the engine? Burning the oil would lower your octane rating and IC efficiency. Maybe enough for 2HP?
