I have access to a 90-91 AWD Wagon. Will the springs/struts work in my 92 AWD Sedan?
Thanks!
Suspension interchangability?
Jason
90 Mirage AWD "LIL EVO"
93 Lexus LS400 "WNTR BDR"
92 Legacy AWD Sedan
96 Kawasaki 900zxi PWC
92 Legacy AWD Sedan
Well, do they interchange or not?
Online parts list 90-91 as different part numbers than 92-94s, but they look identical.
I can get these struts and springs for $25 each.
The previous owner tapped an offramp barrier and the left rear wheel sits at 3 degrees of positive camber. Nothing is visibly bent in any of the subframe arms so I'm thinking it's the strut based on the design of the suspension.
Lastly, I picked up the car for $200 and it's my third car. Cheap is the key idea.
If you change the struts as a unit (Strut, springs, seats and tops) then yes, they will bolt in. You cannot change just 'parts' without doing the research.
Basically the stickies will tell you that '92+ had different spring seat heights.
Also, the rear springs from a 92-94 aren't tapered and the rear springs from 90-91 are tapered so if you mix and match parts you'll need the top hats that fit the springs you're using.
- quasi-mod-o
As Phyrra said, if you change the complete strut assembly over, yes, they will bolt in.
If you're swapping springs and so on, then yeah, some stuff won't swap over.
Check the sticky at the top of the forum. There are many threads in there that have all this information.
2000 Subaru Legacy B4 RSK
*Formerly DerFahrer*
