E85 and 800cc injectors and 19 psi = .........
douglas vincent
Post by douglas vincent »
Well I found out how much 800cc injectors and E85 makes….
Not much.
The motor made a max of 288 whp/330ish torque @ 21 psi and ran out of injector @ 6000 rpm.
Turning the boost down to 19 psi was 265 whp with a moderately safe tune. But the MAF was hitting 5 volts with the piggyback adding in voltage up top….
This was done @ PRE on a DynoDynamics dyno. Sorry, neglected to get a dyno sheet. The torqe and power curves were good up until 5000-5500 rpm when I would start to degrade a bit. I was having some missing issues (we were pretty sure it wasnt det), and this could have been old sparkplugs. The AFR line was pretty damn ugly. "Safe" but ugly. The Walbro 255 just wasnt able to pump enough down low 4000-5000 rpm, then the fuel pressure would ramp up some due to the boost level, then the MAF would run out.
Since it may be awhile before I find (if ever) 1200cc sidefeeds, I am switching back to gas, as I have made 100+ more hp with the same setup.
Ah well, I just wanted to see what the injectors and E85 was good for, and now I know.
Post by entirelyturbo »
Well, as we've discussed, ethanol only has about 50% of the energy that gasoline does.
Was this on an EJ22, or that EJ257 you've been working on?
*Formerly DerFahrer*
Kelly
Post by Kelly »
Ya, that hippie juice sucks Doug. You need to go the other direction, Nitro Methane. :-D
On a stock 22T? I would think the compression is too low to take advantage of the higher octane rating of E85. Also, what are you using for engine management? Standalone would prolly be best for the need of adjustability.
DerFahrer wrote:Well, as we've discussed, ethanol only has about 50% of the energy that gasoline does.
It's about 75-80% of the energy content of gasoline.
douglas vincent
06 2.5 RS block.
The next day I pulled the fuel pump and the filter sock was CLOOOOGGGGGGEEEEEDD!
No wonder I had weird AFRs
Ethanol will do that.....it'll clean any and all junk out of your tank.
douglas vincent
I doubt it was the E85. I only ran it about a week, if that.
I think the tank was already dirty and I ran 15 gallons of Torco through it!
Can you advance your timing at all? With the added cooling you should be able to crank it up a bit.
tmarcel
Re: E85 and 800cc injectors and 19 psi = .........
Post by tmarcel »
douglas vincent wrote: I was having some missing issues (we were pretty sure it wasnt det), and this could have been old sparkplugs. The AFR line was pretty damn ugly. "Safe" but ugly.
You sure that the "safe" AFR was OK? Sounds like you may have been dumping fuel. What was the AFR when the missing was happening? Could also be ignition timing related.
1.) '02 WRX-2482cc-TD06H-20G-FMIC (just sold)
2.) '90 Legacy-2.5 turbo, VF39, Haltech E8 in-hand - waiting for the 5mt swap
douglas vincent wrote:I doubt it was the E85. I only ran it about a week, if that.
Don't be so sure....ethanol does some nastly shit to metal in a very quick amount of time.
I'm sure the torco didn't help either.
douglas vincent
Well, after pulling the plugs and regapping them to .028, everything is dandy.
tmarcel
Post by tmarcel »
douglas vincent wrote:Well, after pulling the plugs and regapping them to .028, everything is dandy.
Do you recall what your AFRs were? Was it mapped by gas AFR or Lamda? Just curious.
douglas vincent
Gas AFR.
Was shooting for 11-1 or so. But couldnt get there due to the filter most likely.
tmarcel
Post by tmarcel »
douglas vincent wrote:Gas AFR.
You'll be a lot better off at 12:1 using gas AFR. That will greatly extend your fuel injectors too. 11:1 is probably just too rich. How does your timing look? Can you post an image of your timing map and/or PM me.
douglas vincent
Well, thats about what I was getting (11.5 :1) but it was RAGGED.
Timing is whatever the NA ecu was shooting, with about 4-6 degrees pulled.
Its really a moot point at this stage. I obviously had fuel system issues, so all ideas are theorys for now.
tmarcel
Post by tmarcel »
douglas vincent wrote:Well, thats about what I was getting (11.5 :1) but it was RAGGED.
Cool, will you try again on E85? Might as well since you've gone this far. I'm still confused as to what an NA timing curve looks like, well at least under boost on an old school Subie. The newer Subaru ignition mapping runs out pretty quick and doesn't compensate for the additional airflow = LOAD.
Legacy Rally Guy
Post by Legacy Rally Guy »
Very cool, but yeah, you're right, Ethanol just doesn't have the volume : BTU of gasoline... A shame we can't get leaded fuel anymore for race nights..... hehe. lead made it some HIGH octane stuff.
And a big bummer we HAVE to run 10% ethanol in our fuel here in Missouri... Now if I could only get the 93 Octane we used to have WITHOUT Ethanol.
I dont even know if we've an AWD dyno here anymore...
tmarcel
Post by tmarcel »
Legacy Rally Guy wrote:Very cool, but yeah, you're right, Ethanol just doesn't have the volume : BTU of gasoline... A shame we can't get leaded fuel anymore for race nights..... hehe. lead made it some HIGH octane stuff.
I wouldn't turn your back on ethanol. Hopefully that's not what you took from this thread? The OP had a clogged fuel pump AFAIK, which probably lead to his issues.
Many cars have made great power on e85!!
darkcrave
Post by darkcrave »
Hell of old status, but what were the complete mod list when running this?
douglas vincent wrote:Well I found out how much 800cc injectors and E85 makes….
Not much.
Tune
TMIC
Fuel
Taillight
