Cruise control
steelcitysubie
Cruise control
Post by steelcitysubie »
I have a 90 legacy wagon 5 spd and the cruise gave out on me during a long trip. After that it would work for about 10 miles then give out. When I push the cruise button I hear a clicking sound behind passenger side dashboard. Any clue?
90 legacy wagon 200k and going strong
You dont make friends with salad.
ultrasonic
Post by ultrasonic »
The clicking is normal. It's the relay.
If you have cruise control for a short period of time I would suspect a vacuum leak. Either a small leak in the hose to the actuator, or more likely it's the actuator itself. It depends on vacuum to control the throttle position. Sounds like a slow leak ,so it holds position for a while, but as the vacuum leaks down it can no longer hold throttle position.
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
steelcitysubie
It only worked like 5 times after the long trip. If I played with the swicthes for a while it would work sometimes. Is there a criuse amplifier or a computer?
BSOD2600
Post by BSOD2600 »
Work sometimes... as in the computer would forget what your cruse speed was set to? Mine does that too some times.
'11 WRX Limited
'94 TW | R.I.P.
steelcitysubie
Theres no vacuum leak and the controller that is on the cruise cable holds vacuum. I traced the vacuum line to another part with a 4 wire plug. Could that be the problem? Can I test that?
That's the vacuum pump. I would try and test for vacuum.
