Cruise control
steelcitysubie
Cruise control
I have a 90 legacy wagon 5 spd and the cruise gave out on me during a long trip. After that it would work for about 10 miles then give out. When I push the cruise button I hear a clicking sound behind passenger side dashboard. Any clue?
90 legacy wagon 200k and going strong
You dont make friends with salad.
ultrasonic
The clicking is normal. It's the relay.
If you have cruise control for a short period of time I would suspect a vacuum leak. Either a small leak in the hose to the actuator, or more likely it's the actuator itself. It depends on vacuum to control the throttle position. Sounds like a slow leak ,so it holds position for a while, but as the vacuum leaks down it can no longer hold throttle position.
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
03 Legacy L Wagon
steelcitysubie
steelcitysubie
That's the vacuum pump. I would try and test for vacuum.
