2nd, 3rd, and 4th gear lockup?!
James614
Post by James614 »
Quoted from this site's Turbo review of a '91 SS:
The Legacy Sport Sedan electronic transmission is uprated to handle increased torque. Changes include a larger microprocessor-controlled lock-up torque converter which controls lock-up in second, third, and fourth gear;
Is this true? I read on one of Josh's scans that they changed the shift mapping for the 92-up transmissions, raising shift points and modifying lockup. And my wife's 91 L definitely gets into 4th locked much more readily than my '93 L did or my '93 TW does. But I've never experienced any locking outside of overdrive on any Subby. But then again, I've never ridden in a '91 turbo.
If I could swap in a '91 turbo TCU and get 2nd/3rd lockup that'd be freakin' sweet. I've already been kind of itching for a '90/'91 TCU just for the earlier overdrive lockup.
You could try it. I don't see why it would cause any harm.
James614
Post by James614 »
I'd definitely try it if I ever came accross a '91 SS in the 'yard (I have better chances of winning the lottery, though). My main question was if anyone with a 4EAT '91 SS knows if it actually locks up in 2nd and 3rd. Otherwise, I can just go after any '90/'91 TCU for the earlier 4th lockup.
I have a '90 TCU from an NA and another TCU from a turbo wagon. I drove them back to back, and there didn't seem to be much of a difference. This was only on dry roads, and only with NA torque being put through an NA 4EAT.
I'll sell you both TCUs if you want to experiment!
Post by 555BCTurbo »
I believe I have 2 Turbo TCUs that could be had for VERY cheap...both work too!
jeffast
Post by jeffast »
hrm, i can say almost for certain that my 92's tq converter has never locked up in any gear but 4th and even then you can tell it takes some effort
92 SVX LSL tour- 5spd swap baby
92 turbo touring wagon now also 5-speed swapped
89 xt6 stock
[quote="danetrain"]Fuck wyoming[/quote]
